I need to change the u-joints on my Mercruiser Alpha One.
I have the outer yoke off, and the center socket ring, leaving only the inner u-joint in place at the lower unit. The end caps of the j-joint next to the lower unit won't come off because the retaining nut driveshaft housing is in the way.
Can I just use a grinder to grind a slot big enough for the cap to slide out, or is there another way of getting this last u-joint out?
Thanks,
Mike
Thanks,
Mike
