proaudioguy
- Joined
- Aug 12, 2010
- 171
I have a V4 140 Evinrude 25". I have a Stratos 200DC 20ft dual console. It's not a bass boat. It's more like a fishing boat/ bow rider. The transom is cut out, the engine mount sits high with a large gap at the top where it might normally be attached to the top of the transom. I'm thinking perhaps this particular boat should have a 20" instead of a 25" but I just don't know. Looks like the guy my dad bought the boat from did an OK job getting it close, but I want to get it RIGHT.
I went through a prop wizard on another site (don't remember where) and it said I needed a 13 1/4" x 17" or a 13 1/4" x 19" prop. I want to be able to pull a skier or two or go out fishing for the day. In either case the prop wizard says use the 13 1/4 19". The 17" is only recommended for the casual cruising scenario where the additional load is not there. It currently has a 15" x 17". How far off is that really? Props are really expensive apparently. I don't know what to buy. At wide open throttle we do have a bit of cavitation (I think that's the right word for what is happening). I back the throttle down once it's on plane, and it stops gurgling back there. Then I can push it up a little more. Before this week I had not been able to get it on plane much. I am gradually fixing all the issues with this boat and learning a lot in the process. I also can't figure out where to trim it and when. My nick should be NOOB!
