Re: How do I use a test tank?
ok
basic sensors on the SX250
O", measures the amount of oxygen in the exhaust, used to fine tune fuel delivery. if the signl to the ECU is faulty or missing fuel is fixed rich at low speed and lean above 4000, DO NOT run above 4000 or lean piston failure is likly.
map sensor, measures barometric pressure at key on then measures intake presure to monitor engine load, used to correct fuel.
crank position sensor,used by the ECU to determine crank angle and engine speed,Throttle position sensor,used by the ECU to determine throttle angle and the speed of throttle opening to adjust timng and fuel injection asychronus or synchronous modes.
Knock sensor,used to detect engine knock, will add fuel and decrease timing if knock is detected.
coolant temp sensor,used to detect engine temp for fuel correction mainly when warming up and once engine is warm,has nothing to do with over temp detection.
intake air sensor used to measure air temp. its also why this set up is referred to as a speed-density type EFI used to correct fuel for varying air temps(density).
if any sensor FAILS other than the O2 sensor the timing will be locked at 7* BTDC and idle will be about 1200 RPM. some failures will allow top speed others wont.
most isues are VST and lift pump related.
study your manual but look on the net for basic EFI and how and why it works. doesnt matter much if its in a car,truck boat or airplane, speed-density systems all tend to work the same.
fuel tanks can be tough to clean, make sure your hull mounted filter is 10 micron with a clean flow capacity of about 90 GPH.
once you have the engine back in the 5200-5600 RPM range I have had success with starbrite fuel system cleaner. but DO NOT use it until the engine is running well, by the time any system cleaner starts actually cleaning usually ya burned a piston due to lean fuel.
