Have a evinrude ficht 200 hp. Found in the book about the codes flashing on the Check engine light and how to set up to make it flash. Book says it's a two digit code but does not explain the sequence. Some one had posted a code flash sequence for twelve on another post and we could not figure out how the sequence would equal 12.
Will it flash once then pause for (let's say 2 sec.) then flash two more times for 12. The sequence the guy had posted was on - off-off -on off on off off on. If there is more than one code what tells you if there is another code coming? Thanks in advance.
