how do you bleed hydraulic trim system
dirtymike
I have a 280PT outdrive that I just replaced a hose on that feeds one of the hydraulic trim cylinders. How do I fill and bleed the system? I haven't been able to spot reservoir yet either.
erie_guy
Re: how do you bleed hydraulic trim system
Not knowing what boat you have makes this difficult. I would look on or near the inside of the transom to find the hydraulic pump/ reservoir. Perhaps sound of the hydraulic motor could lead you to the assembly. Once you find it, check the level (often visible through the side of the reservoir).
I believe cycling the drive up and down a few times will purge any air from the lines and cylinders. Just keep the reservoir full.
Best of luck
erie_guy
Port Clinton, OH
Vinnys
erie guy is right on both accounts. Cycle the trim and make sure the fluid level stays full.
Good luck
dirtymike
I will take some pictures of the inside at the transom. It is a 1979 formula 233 interceptor with the chevy 350
If just going up and down a few times will work that would be amazing, once I find the reservoir tank
dirtymike
ok well I have not been able to figure out where to add fluid to it, I don't see the a reservoir
here is a picture of the trim motor, right next to the remote mount oil filter. The outdrive is a volvo 280pt
RandyJ
Not the same as the set ups I'm used to but looks like that box under that electric motor is your reservoir. It should have a screw in one corner of the top of the box... your fill hole. Pro'lly on the right where the indention is at the corner.
