Re: How do you check compression?
also make sure u open the carbs are in WOT (wide open throttle) u will get false readings
u want to be within 10%, bu really 5% is less is perfect, 6-10% is OK anything over 10% is check out things like head gasket,rings, pistons etc
if u have a emergency stop switch (ESS aka Kill switch) u can pull that and use your key switch to turn over the motor
using the jumper is not the best thing to do, sparks and gas are not a good combo
the best is go buy a remote starter
invest in a good gauge!
taking plugs out are good, no wear on the starter, but bad u got fuel and oil flying out
leaving plugs in, more wear on the starter, no oil/gas flying out, and u have normal operation conditions with them in
when i test i leave them in
does your motor use them with them in or out8)
