Volphin
- Joined
- Jun 5, 2011
- 1,405
Hi everyone,
I was finishing up my repower on my 89 Regal 4.3L A1 and decided to check the gas. Ug. Water in the fuel from the sample I pulled. I have an electric fuel pump with no water separation system. I can get most of the fuel out by pumping it directly out of the tank using the fuel pump, but then what? This tank is built into the bowrider and under the floor. I can pull the sender and let the offending water and fuel evaporate... but can't remove the tank. Can anyone provide any tips or pointers?
I am almost done rebuilding the 1409 Carb. I had even had rust on my Accel pump spring! I knew holding on to that 5 gallons of carb dip would come in handy!
