Re: how do you get the flywheel off? I took off the top nut
Would like to add a couple of tips here.I use an automotive wheel puller for a harmonic balancer. You mat wish to use several large and thick flat washers in order to keep the heads of the bolts from pulling through.be certain that you thread all the way into the flywheel otherwise you run a large risk of pulling the threads out of the flywheel.I would also recomend you use a good chemical wush as WD-40, and soak the heck out of the flywheel threads let it stand and soakem again.use patients with this as a flywheel isn't cheep to replace.
