Re: How do you get the "Pee Stream" on the older outboards?
It's very simple. Get a fitting (number 321886), drill and tap into the water jacket on the top of the block above number one cylinder (flat area). Drill into the BLOCK, not the cylinder HEAD. The water jacket (space)is about a 1/4" deep at the top. The block itself is an 1/8" or so. I go forward of the head gasket a 1/2" or so and center in the flat area. <br /><br />Seal the threads with non-hardening gasket sealer and screw it in. Drill the lower motor cover where you want the stream to exit and install fitting number 321885. It just pops in. <br /><br />Connect the two fittings with a hose and youre all set.<br /><br />Good luck and enjoy!
