how do you know if transom bad?
budman8330
Re: how do you know if transom bad?
You mean transom ? <br /><br />if so, check to see how much flex it has when you push down on the motor. If its excessive, replace it. Every boat i have ever owned had light flex, but i was always told that it should. <br /><br />Thats how i have always knows, by eye. But, when in doubt, tear it out. I would anyway just for the fact that the boat is a 78
rolmops
This is the wrong forum to post in.<br />If it is wood,just take a pointed knife and see if you can drive it in over 1/2 inch.If you can the wood is rotten.If fiberglass,check for cracks.Pull the engine back and forth and see if the transom moves along with it.It is just common sense.
