Re: How do you know what prop size and pitch to get??
Increasing the pitch causes a prop to take a bigger "bite" of the water, which means the engine must do more work. That's why the top rpm of the engine decreases at wide-open throttle. If the prop has too much pitch, the engine "lugs" all the time, which can cause internal problems if it continues.<br /><br />Too little pitch can damage an engine faster because it allows the rpm to exceed the "red line." Over-revving an engine can turn it to scrap in only a few minutes. As a rule-of-thumb, changing 1 inch of pitch will cause an increase or decrease of 200 to 300 engine rpm.<br /><br />The correct pitch allows the engine to reach its full rated rpm at wide-open throttle, but no more. If you want to go fast in a light boat, you will want a high-pitch prop. However, you will have to reduce the pitch to get the most out of your engine when the boat is loaded.
