How do you remove torsional damper on 1999 4.3l vortec?
toolman4
I believe the prop turns counterclockwise on my 1999 starcraft 4.3l vortec. I assume the damper bolt turns counterclockwise but want to make sure before I put too much leverage on it. I have the service manual, but do I need the tool to take this off and put it back on the new long block correctly? Also on my new exhaust 2 piece manifolds instead of one, do I need a 3" rise or 4" rise.
Bt Doctur
Re: How do you remove torsional damper on 1999 4.3l vortec?
thinking you mean the harmonic balancer on the front of the engine. Yes, a special tool is needed ,a balancer puller and installer.
toolman4
How do you remove harmonic balancer on 1999 4.3l vortec?
Thanks Bt, yep the balancer on the front. Wow that baby is expensive!:eek: After reading I might be able to rent one. Does the bolt in the middle turn counterclockwise to loosen?
