how do you rig a spinnnager
newportbill
on my newport 19 i dont know how to rig the spinnager. the boat has upside down loops on each side at the shrouds but if the wind lays alittle the lines drop. what are the pullies at the bottom of the mast for , and you can't see it but right at the base of the mast in the top of the cabin is a hole with a pully inside just aft of the hole. what goes there?
flashback
Re: how do you rig a spinnnager
maybe the down haul, you would need one, although the base of the mast is not the best place to have it..
tommays
Well
If you have a traditional it would be about like this If you google
"how to rig a spinnaker" you will find many photos that will help
This is a good one http://www.dedekam.com/sdetail1.html
jay_merrill
Next question: How do you rig a spinnaker so that you can jibe it?
tommays
End to End OR Dip pole pretty much the same except the two extra sheets on dip pole
srothfuss
Re the pullies on the mast: On my 15' Mutineer there are 2 pullies [1 above / 1 below the spinnaker pole] to help control the level of the pole from the cockpit. My bottom pulley really doesn't have to be a pulley, as I use shock cord to keep tension (downward) on the pole. Then the crew can use the upper line to keep the pole level.
Definently check out google for some great documentation. Have you hooked up with an online group of NewPort owners yet? I'm sure they are out there...
cgBosun3
If your boat is set up for a spinnaker, ther should be a block(pulley) at both quarters(aft corners). The spinnaker sheets run thru them back to teh cockpit. The spinnaker halyard shoud run from just above the jib halyard to maybe the base of the mast, or more likely the back of teh mast at cockpit level. The uphaul/downhaul can bevery simple as described before.
Jibing a chute is simple, with a LOT of practice! Head the boat dead downwind, unclip teh spinnaker pole from teh mast and attachit to the clew(corner) of the chute that is loose. The pole now is attached to both lower corners of the sail. Jibe the main across and get the boat stable on the new tack. Now unclip the pole from the firsr clew and attach it to the mast.
YOU DID IT!!
Get out and practice again and again in light winds, then impress your friends with your skills!
Clam Biter
On some sailboats the main halyard goes over a pully at the top of the mast and down through the mast and out the little hole and to one of the cleats on the cabin top. the jib and spinnaker halyards reave through the pulleys on the side of the mastand also to cleats on the cabin top. As for rigging the spinnaker, if it is still in print, a book called Royce on Sailing would be a great help.:confused:
jay_merrill
The pullies are there so that you can thread the halyards (main and foresail) back to the cockpit of your boat. From your photo, it looks like you have friction blocks to stop the halyards, rather than cleats.
A spinnaker has basically the same components as any other headsail, but is shaped differently and is used differently. The main difference is that a spinnaker is basically symmetrical and has a line called a guy, which alternates in function with the sheet, depending on your point of sail. Because of this, the tack and clew also alternate. A spinnaker pole is also used with both a topping lift and a downhaul. These are needed to properly control the sail.
Although some sailors don't do so, a spinnaker can be jibed. At first, the technique seems a bit complicated, but once you practice it and get crew members in sync with one another, its not hard. The trick to jibing a spinnaker on some boats, is in having two guys and two sheets rigged to the sail, so that it can be controlled as the jibe occurs. A crew member must also switch the spinnaker pole as the jibe occurs - the end that was attached to the tack must be released so that side of the sail can become the clew, and the other end is clipped into the opposite side of the sail, so that it can become the new tack.
While a spinnaker can certainly be jibed with only one set of lines for the guy and sheet, the dual line setup is most often used on larger boats. On such boats, there are normally enough winches and crewmembers to effectively use the second set of lines. The dual line setup is also effective when racing because a well practiced crew can execute the manuever in a way the minimizes or eliminates loss of boat speed.
The purpose of dual sheets/guys is to allow this to happen while maintaining full headway and control of the sail. The procedure is to initiate the jibe and to make the spinnaker pole adjustment as the boat riches the midpoint of the manuever, with the wind directly astern, or nearly so. At that time, the pole is disconnected from the mast and from the old guy. The crew then maintains control of the sail with the "old lines." The end of the spinnaker pole that was attached to the old guy, is then attached to the mast, and the opposite end is attached to the slack line (2nd line), on the side that is to become the new tack. During this manuever, the pole is "floated" on the topping lift. After the change is made on the spinnaker pole attachments, the crew takes tension on the secondary lines, which have become the new guy and sheet, trimming the sail as needed.
I may have missed a couple of points, because I haven't sailed in years, but those are the basics. Here's a link that gives a pretty good description -
http://www.bostonharborsailing.com/results/manual-Spinnakerclassv1.pdf
PS: Dang! I gotta start looking at the original post date when I see these threads. Guess I'll leave my post up anyway - someone might find it useful.
