Re: How do you test a VRO warning system
Being no expert here at all, I know at least 2 things you can do:<br /><br />1. Before any test, hook motor up to an external gas tank, with 1:50 premix. Run it till you are sure straight gas in carbs is out and premix in.<br /><br />2. With motor running, slowly empty oil tank with a hose. When an 1" is left, the low oil warning should sound.<br /><br />3: Disconnect oil hose from motor, and start it running on premix. Within some time, the no oil warning will sound.<br /><br />I dont know any other tests, wait for someone elses advise too. <br /><br />After connecting hose again, mark oil level on oil tank, and run a couple of tanks of 1:50 premix through it, while you observe that correct oil consumption is present and all connections are tight. Recheck all clamps. Then go to straight gas again.
