How do you track hours on your outboard?
zippy83
What would be the easiest way of tracking how many hours I put on my outboard? Mine is a 73 mercury so I really cant hook it up to my Lawrence HDS 7 to monitor the outboard performance. Does it also count when the outboard is on in idle?
Thanks
Zipp
GA_Boater
Re: How do you track hours on your outboard?
Easiest way is to add an hourmeter powered by the run position on the ignition switch. Yes idle time counts.
kfa4303
Banned
Tiny Tachs have an hour meter on them and show you the rpms of your motor as well. Many modern stock gauges come with them too.
Sea Rider
Check Hardline Induction Hour/Tach, easy to install, could trim unwanted cable lenght once installed. Order the model with a 2 code ending, has programmable fire sequence, for multipurpose engines. A must install if wanting to know engine total worked hours, ideal for preventive and correctve maintenances.
Happy Boating
dingbat
I don't...it's a frivolous measurement.
Home Cookin'
I added an hour meter when I bought a used boat; it simply measures the time when the key is on (so if you left the key on by mistake overnight you rack up the hours!).
Sure it's frivilous but what about boating isn't? I watch it for curiousity, for replacing a water seperator, and it was invaluable for the break-in timing on a new lower unit. No way you can estimate with a wrist watch and a day's outing, if like me you often turn the motor off to drift, anchor, beach, go ashore, etc.
When you start with an old motor it won't tell you anything about that motor, but hours used are not that important except in the cases of extreme high use (1000/year) or under use (10 hours a year). IN fact an under-propped boat (ie too high RPM) can add an hour of wear for every minute it's run.
When the manufacturers recommend service at "one year or 100 hours" I take that to be the estimate of expected typical use per year. But there are way too many factors to say what's normal, including boating season length and typical trip distance (that is, some people use the boat right in front of launch/mooring; others typcially travel a distance to get to the area where they spend the time fishing, beached, etc. or to get beyond the interminable no wake zones in heavily populated areas.)
i agree. unless you are a commercial fisherman where you need to plan replacements based on high hours of motors, it is meaningless.
most people put less than 25 hours a year on their boats. A good friend of mine who lives on a lake, is the first boat in the water in spring and the last boat out, boats at least 4 times a week and puts only 100 hours on in a year.
Sea Rider
Don't you guys perform cars maintenences as per odometer, same should be applied to outboards, assume will love it if comes factory standard installed. No way you could track run hours by a wrist watch eternally, Did not realized how cool they were untill started to add them to portable engines. Induction tachs and hour/tachs are great, low money well spent.
Happy Boating
dingbat
No.....I don't subscribe too, nor believe in, time based maintenance schedules.
What are you maintaining on an outboard that needs requires clock like precision? The only hourly maintenance recommend by my manufacturer is a fuel filter change every 100 hours. At $30 a piece, I change my filter when the vacuum gauge says its time. Usually upwards of 300 hours. Everything else is "annual" maintenance and I certainly don't need an hour meter to tell me a year has passed. :confused:
Sea Rider
Dingbat,
Will depend on the engine you are currently using and type of boaing you like doing. Can't mix a portable, medium range, large outboard HP engine in same sac. Personally as we boat all year round don't believe in anual maintenances, just change spark plugs, LU oil, clean internal mesh fuel filter every 100 worked metered hours and that's it. For $ 40-50 US made hour/tachs shipping included is a well spend money, my engine runs happily all the time like a Swiss clock.
Happy Boating
dingbat
Dingbat,
Happy Boating
As noted above, I can put 100 hours on the motor in a week. Do you really think it's necessary the change spark plugs, LU oil and fuel filters on a weekly basis?
"Clean Internal mesh filter? What the heck are you using?
Geez, I can tell it's winter because a simple question about how to track engine hours gets turned into a long drawn out discussion on the merits of engine maintenance schedules. :facepalm:
Home Cookin'
....most people put less than 25 hours a year on their boats....
If that were true, it would just be sad. I don't know where you got that "statistic" but it certainly defies experience in the mid-Atlantic. True, I see a lot of boats hanging on lifts that get a lot more air time than water, but for the ones that seldom go out, there are heavy users from early spring into the late fall, plus the fishing through December. And the Southern coastal regions are year round; I would think the southwestern lakes would be, too.
I can't see how a northern lake boater could justify having a boat in the first place for 25 hours a year. That's like me buying a snowmobile.
Figure your hourly cost of boating fun at 25 hours v. annual maintenance and possession costs plus depreciation--it's like a luxury cruise!
the statistic comes from a particular engine manufacturer's warranty and service data
while you may be right it is a luxury cruise. at 25 hours per year it doesnt justify a boat. however people buy boats, convertibles, snowmobiles, hunting riffles, swimming pools, etc often without any more justification than "i want it"
garbageguy
yep, it's winter alright - so I'll chime in, what the heck
I keep a simple log book for all outings and maintenance. It includes entries for approximate hours of each use, fuel amount and cost. It gives me an idea of my use, maintenance and costs so I have some idea of how it fits into overall budget. It's one of my boating rituals, and is probably mostly frivolous. But its part of boating for me, and I enjoy pretty much every about boating.
Sea Rider
Probably you are one of a kind boater putting 100 hours weekly, that's you. Exceptions are most of us here. 100 metered hours is what usually all outboard brands recommends regarding LU oil change, if going longer is up to everyone. My local cost to change 2 spark plugs and LU oil is just $ 9.00 peanuts cost, why not change them at each 100 worked hours. A mesh filter is a filter loceted betweeen fuel intake and fuel pump, most outboards has them, just unscrew, clean mesh filter and screw back in.
Going back to the original thread, Zippy 83 just asked how do you track hours on an outboard...
Happy Boating
zippy83
ok I think I got what I need. I will probably get the hour meter this week and install it next week sometime. Going back to the 100 hours discussion I will plan on doing regular maintenance every 100 hours or every year whichever comes first :)
Home Cookin'
your first goal is to enjoy the boat at least 100 hours a year!
phillyg
My previous boat didn't have an hour meter so I just kept a written log, and yes, idle hours count.
