Re: How does the ignition work
I have 2 manuals.<br />The factory Johnson, and the Clymer.<br />They don't get that deep into how it really works.<br />They just say, "If that test fails, replace the,,,,,,,,,"<br />Or, in my case, "If the idle timing is not within these specs, go back and perform the link and sync operation from chapter two!"<br /><br />Someone here said, "Just set the idle timing with the screw, and it will take care of it's self."<br /><br />What does that mean?<br /><br />On a Ford, for instance, you set the static timing with a timing light, rotate the distributor, and plug the computer cable back in.<br />It does in fact, take care of it's self.<br />But, what I have seen so far with my Johnson, it is about equal to the old points and weights type of igninion, only without the points, and a mechanical linkage instead of weights. I don't even see any means of vacuum advance, so it is even more caveman than that. There is some kind of capacitance system, that advances during the "Quickstart", but other than that, there is no mention in the manuals of some other means of a "closed loop" advancing methode.<br />Simular to a eary model Briggs and Stratton.<br /><br />I'm sure one of you mechanics with 30+ years must know if there is sutch a system there.
