Where might water enter the gear lube if the boat has only been run on muffs? i just replaced the bellows, put the outdrive back on and ran it on the muffs. Checked dipstick and lube has foam on the top of it. level isn't higher so maybe it isn't water, but if it is, where can it come from? is there a seal in the water pump/impellor area that needs to be checked? omc 2.3l 1988.
