Re: How far can I safely trim out drive at WOT?
First, Injun, that is incorrect with a Merc. OBs yes, I/Os no.
Second, Maclin, if he has a heavy bow and/or a low X-dimension, It may not porpoise or lose bite before it is too high.
And Third, Chapdude, go back to your control and tell us what model number it is and double check the up switch. I'll bet it has two "levels". You should be able to click the button lightly and then push harder and get a second click . . . All of them have trim limit unless the handle is bad, non-Merc and incorrect, or it is a Merc one and it has failed . . . Do not depend on the gauge until you know where the trim limit is as the gauge can be adjusted just like the trim limit, so it is possible that halfway is perfect on your gauge and 1/3 is the top of trim on mine . . .
Usually about a third of the way though on the boats that I have driven. Including Volvos.
