vaughneric2000
- Joined
- Jun 5, 2004
- 28
Hello all:<br /><br />I have a 16 Ft Alumacraft with a '78 55HP Johnson. I recently added a "Dolefin" to the motor to get a little more stern lift. The fin works great; however, as a result, as soon as I put the fin on, I lost a little over 1000 RPMs at WOT. The motor was hitting 5300 Max RPMs at WOT prior to the fin install. After the fin install, Max RPMs at WOT dropped to 4250. <br /><br />Holeshot is not very important to me, and I'd like to get those RPMs back.<br /><br />After reading extensively through posts on this subject (motor raising to regain lost RPMs), it's obvious that I need to raise my motor on the transome. My motor is mounted using its lowest holes. There are three more hole settings that I can use to raise the motor on the transome.<br /><br />I have three questions:<br /><br />1. Should I go ahead and raise the motor to its highest possible setting? <br /><br />and/or, <br /><br />Is there a point where raising it too much would be counterproductive to getting back my RPMs? <br /><br />And if so,<br /><br />How can I tell how far is too far in rasining the motor?<br /><br />Thanks a million,<br /><br />You guys are fantastic! I have yet to receive a single piece of incorrect information.<br /><br />Thank you! Thank you!<br /><br />Eric
