Re: How far up do tabs go????
Look,<br /><br />There seems to be a lot of confusion here. You can not simply move the cylinders up a little bit and you can not simply move the mounting point back a little bit.<br /><br />The piston bolts directly to the very back edge of the trim tab, on a section that is bent up. There is no place else to mount them, so moving the mounting position back simply is not going to happen.<br /><br />On the top end of the piston its held in place by three large screws (usually #12 or #14) and right dead in the middle of all of that there is a 3/4" hole going right through your transom. Moving the tabs up means that you have to remove it from its mount. That means removing the hydraulic line, and then filling all 4 holes, and then remounting. You aren't going to be able to do any of this with the boat in the water - no way on earth.<br /><br />Also, under no circumstances should you disconnect that piston from the tab plate and then take the boat for a spin. If you do you'll be dam good and lucy to have a tab when you get back or to find that you have a transom that isn't beat all to hell and gone.<br /><br />If the boat is in the water and you're in a place where its even a little bit warm just take a straight edge (aluminum yardstick will work just fine) and jump in. Have the tabs in the full up position and press your straight edge up against the bottom of the hull so that it extends out under the tab plate. If the straight edge is agains the hull you'll see if the tab properly mounted or not in a heartbeat. If its not this is going to require a days worth of work with the boat on land. There is simply no choice about that. Screwing around with anything else is just wasting your time.<br /><br />Thom
