Re: how fast you think it should go
Very Opened ended, so may variables. Does the power trim work on the motor, is it on a jackplate or directly on the transom. How high is the motor mounted? Where is the weight situated in the boat. Without more info, i will assume you are bolted straight to the transom, and probably pretty low, so i would agree with 50 mph. I can grab 54 with a 115 on my '79 checkmate, which is a similar performance hull to your baja, but slightly lighter because of construction techniques. I also have 6" setback on my motor and it mounted about an inch below "pad".
