How fast?
Hoyt79
Just wondering...I have a 1972 15' Terry bass stick steer (it's a crappie design) with a 50 hp johnson and clocked it at about 30mph with 240 lbs of warm body weight...is this about what it should do at WOT?
boobie
Re: How fast?
To many factors involved to give you a decent reply. You may want to post this in the boating section of this forum.
BonairII
Re: How fast?
Only way to know if your optimizing speed and overall performance is to use a tach. Your motor has an RPM range stamped on the transom clamp(probably). You then prop your motor to reach max RPM at WOT.
