How flush Mercury 3.0 TKS
rnorman3
Hi, when I get out of the salt water I flush the engine by connecting the muffs and a hose and then starting the engine for a few minutes. However I got thinking that if the thermostat is closed (since engine does not reach temperature in short time) then how does the block then get flushed? Do I have to wait for the engine to reach temperature to open thermostat? Is there an easier way?
Thanks!
Faztbullet
Re: How flush Mercury 3.0 TKS
You should have the "t" handle block /drain system, just use it to drain block and manifold then start and flush on muffs for a few minutes..
