Re: How from the keel do I mount my Johnson 50?
The installation height depends on several factors.
The deeper the V-bottom, the higher you may lift. (flat bottom, just above flush).
Propeller type. (cupping and SST props normally allows more lift).
Flat water or open ocean?
Priority of top speed, hull-shot, low planning speed?
There are general rules as mentioned above, but at the multiple tests should be done to get what you want out of it.
