Re: how good is a 25 hp 1969 evinrude
The '69 doesn't have a $250 powerpack to go out. SO sadly, you'll have to spend much less if you have ignition troubles, plus you'll probably be able to get home on one cylinder if you have spark problems instead of getting to have a nice paddle back home in case the powerpack goes out on a newer motor. It has virtually the same type lower unit as motors today. The '69 isn't full of plastic so that stuff won't break, either. What Samott said.....
The powerheads never changed much, either, or the water pumps.
I'd love to have a '69 25hp, although I'd be tempted to put the powerhead onto a '57 18hp midsection just for fun.
JMO,
JBJ
