Re: how hard to rebuild carbs
Casper, you will want to install new gaskets and a new fuel inlet (needle valve) and it's seat. Also check the condition of the carb float. The foam -type disolve and the hard plastic ones crack. Replace them if necessary.
The trickiest part is to adjust the idle mixture. It takes a bit of trial and eror.
