paultjohnson
- Joined
- Jul 29, 2010
- 1,560
I have been chasing gear oil leakage on my 86 Alpha1 gen 1. I was getting some gear oil leaking after using the boat.. Originally coming out of Stbd weep hole, and water intakes on lower unit. . Pressurized, and sprayed some soapy water on it and got bubbles around the water pump. Replaced base and seals, fixed. Now leakn again. And i am getting a tiny amnt of water in the gear oil. After almost every use I have been draining the gear oil, puttin my pressure tester on it, Normally it holds 15 lbs over nite. Last time it held 18 lbs for 3 days. But its just sittn, nothn turning. So its not leakin much. Some times not at all, sometimes i teaspoon in 2-3 days. I split the drive today,this time its coming down the drive shaft from where the upper and lower drive shaft housing oil seals are. I appears I can replace the lower seal without removing the u joint assem and upper bearing assembly. But to do the upper [ more important] seal, that has to come apart. NOW MY QUESTION... I can get my hands on the spanner wrench. Sooooooooo it it a DIY job ? Can I just take off the big retaining nut with the spanner wrench , remove the top cover. Take out the u joint assembly. Take out the upper bearing assembly from the top. Tap out the lower seal from the top. Tap out the upper seal from the bottom Replace the 2 seals. Drop the upper assem back in, put the u-joint assem back in, alinging up index marks, torque the retaining nut to 200 lbs. Replace the top cover , torque to 20 ft lbs and call it a done deal ? At the start of the season I had the upper bearing and race replaced, rolling torque set and all. I wanna know if i am overlooking something. My mechanic said its only about a half hr job, But I want it done yesterday not a week or more out. Busy season of course here in Mn.It looks relatively straight forward in the manual. but the manual covers TOTAL disassembly and reassembly. I just want to change the seals.. Sorry this is so long winded.... Any body ? Thx !!! BTW I am out of work, Not much $ on hand so I am looking for the inexpensive route until I can get the whole drive resealed....
