Re: How hot can upper gearbox be when running on muffs? Pre-alpha drive..
thanks for the replies so far!
exhaust out the drive, ran it for maybe 2x15minutes with a little check in the middle. ran at various revs, from idle to 2500-3000rpm.
bottom end of the drive was cool, a little higher temperature in the middle section and a bit hotter on the upper.
just changed the bearings in the upper gearbox, and new oil!
never checked the temperature on the drive before, and was a bit supriced, that hot with no load..
