How is gel coat applied?
ba_50
Paint rollers and foam brushes don't work. Sponges fall apart. What do you apply gel coat with?
I did a topper and the paint roller left some fuzz, but not very noticable. It might need a second coat so maybe a light sanding will take care of that problem.
Thanks.
dvan1901
Re: How is gel coat applied?
Some people roll it and tip it with a brush. You may need to comb the roller pad to get all the fuzz out. Others spray it with a gun too.
Terrulle
Try a roller that is solvent resistant. Use a Glasskoter made by Corona. They are available in different naps. The shorter the nap, the smoother the finish. Also gelcoat doesn't lay down smooth because it's thick.With a roller you will still have stipple or roller texture. If it is sprayed you will get orange peel that will need to be sanded smooth then buffed out to shine.
Or,...........
You can Save yourself a Ton of Work,+ Just Paint It........
Tail_Gunner
Bond-o said:
Or,...........
Agreed there, self leveling paint is really a good thing for noivce painter's such a my self.......:love: You can get pro quality finihses with a little patience and work.
