How long does it take for 3M 5200 to cure?
billh1963
I filled a couple of transom holes on my Whaler this past Sunday and the 3M 5200 I used is still very tacky. The directions say it should not be tacky after 48 hours. Does this stuff have a shelf life? I thought I had read before that it should come out of the tube easily but I had to use a lot of pressure to apply it. Any ideas?<br /><br />Thanks!
Paul Moir
Re: How long does it take for 3M 5200 to cure?
It's supposed to loose it's tackiness after 48hrs at 25°C, and 50% humidity. Is it a little colder where your applying it? It should be applied where it will be above 5°C.<br />It takes around 7 days to fully cure.<br />The shelf life is 1 year, but I think it would harden up in the tube rather than stay tacky.<br />Lots of pressure sounds right. Especially if it's at all cold.
bubbakat
bill I live in tenn and I also used some on my boat last week and with the weather the way it is it cured in about three days.
rjarreau
When I did my promaster at the begining of the year, I used it in several places and down here in Louisiana during Feb. it was in the 45-60 Degree range and man It never totally hardend up so I got pissed and removed all of it with aceatone. Perhaps with a little more time It would have cured but I gave it a week and It was still tacky. But time was a factor in my project !!!!Good Luck<br /><br /> http://community.webshots.com/user/reeltime123
billh1963
Thanks, everyone. It's been cool weather since Monday so maybe I'll give it another day or two.
D
DJ
Guest
Put a light on it, such as a yard spotlight. Just warm the area up to about 70 degrees. That will speed up the process tremendously.
thehermit
for the next time there is always the "fast cure" tube.
ThomWV
I don't even try to touch that stuff until after about 4 days and then only in the summer. In the winter if I have to use it I try not to disturb whatever it is for a couple of weeks.
