How long is Stabil-treated fuel "good"?
BonairII
I just removed the bow mounted 12 gallon(I'm guessing) fuel tank from my boat to inspect/service it.
First question....The tank contains about 8 gallons of stabil treated gas, how long is it considered "good"?
Second: If I end up having to empty the tank of the gas(and I see sediment etc on the bottom)...how do I clean out the tank? Can I rinse it out with something?
TBGixxer
Re: How long is Stabil-treated fuel "good"?
I'm speaking from motorcycle experience here. I'm not sure how long the fuel would be good for but my bike sat for a couple years. I siphoned the gas out and gave it a good rinse with water. No issues. On another project I had some corrosion in the tank so I stripped and resealed the interior before using that tank again.
BonairII
I hate to throw away $35 worth of gas, but I suspect that I'm probably better off not taking a chance.
guy74
You can always blend off the old gas into your mower, or car. Just don't put much in at a time. I always burn off my old gas in my JD tractor that I use to mow with.
reddogg
There is a product, though I can't remember it's name, I used to clean out and than seal the inside of a steel motorcycle tank. It worked great so do some searching and maybe this is an option for you.
Red
BonairII
Maybe blending it with my lawn tractor gas is the best idea for it
nwcove
does it still smell like gas, or does it have a hint of that "varnish" smell? if it smells at all like its gone beyond, id take it to the proper place, and get rid of it. i know gas isnt cheap (close to $5 gal here), but risking a problem in another engine to save a problem in your boat doesnt make a whole lotta sense.
BonairII
It smells like normal gas. But I've decided it ain't worth the risk. I'll use it in the lawnmower
paultjohnson
Ive gotten 3 plus years in a car with non oxy premium Sta-bilized fuel
fucawi
Banned
just add 2 % acetone to it and its good again
nwcove
off topic, but fucawi, is your avitar you, or a pic of william shatner aka captain kirk?
mark1961
Ensign
Stabil claims the treated fuel is good for twelve months.....
HT32BSX115
Um.... DON'T put acetone in gasoline. It's worse than ethanol on your fuel system....... Another Snake Oil story.......
NSBCraig
What's the theory there?
I don't think I'd do that.
