Re: How long resin is good for?
The listed shelf life for most resins is 3 months, but that doesn't mean it won't work fine after that, only that some of the properties may have drifted out of spec after that.
The cure rate and properties will change with time and the rate of change can be tough to predict, plus it can vary with storage conditions. Three years is very old though, it may be a solid block in the can, or very lumpy, and even if it is still in a liquid state the final cured (if it will cure) properties won't be as good.
