How long ski rope
carbineone
Hey everybody,asking a question about the upcoming season.Some of you may know I have a little 10 foot GW Invader boat.I want to pull my 13 year old son on a tube and possibly water skis.How long of a rope should I use?I know they reccomend like 50 foot behind a big boat but only like 20 feet behind jetskis.Also which is easiest to pull a tube or skier up at first?A long or a short rope or is there a differance? Thanks
arks
Re: How long ski rope
Yeah, it makes a big difference. Might be best for you to experiment a little with various lengths.
With a low-HP boat I found it's easier to pull up a waterskier than get a tube on plane.
I haven't pulled in a few years but whan I did, we had rigged seperate towlines for each type (tube, kneeboard, skis).
As I recall, the tube towline was shortest- 40 feet. This one didn't have a handle because the tube was directly attached to the line (well, the line had a connector that attached to a nylon strap that wrapped around the tube). We used this on our 23 footer as well as a SeaDoo. The 85HP SeaDoo would work really hard for about 5 seconds to get the tube on top, then it was easy.
Our kneeboard line was 50 feet long. We found that to be the best length for wake-jumping behind our 23.
The regular ski line we used was the regulation 75 feet in length. It was AWSA approved and had pre-spliced sections that could be easily removed for slalom events. We only used this behind the 23.
Hope that helps.
kenmyfam
We use 60ft for tubing and 75 ft for skiing. Pretty standard lengths as far as I know.
carbineone
Thanks to you both.I am maybe thinking 40 on the tube rope and 60 on the ski rope.I was talking to a guy that has a 10 foot Invader with a 25HP Evinrude and he claims with him at 190lbs,his sister at 130lbs in the passenger seat he can easily pull his 115lb nephew on a tube.Mine is a 28HP Johnson so from what he told me I am encouraged by my setup but maybe he is exagerating I do not know for sure,but thats what he claims using these lengths of tow ropes...Maybe I will do what you say,start with the longer regulation lengths and shorten them up in increments and see what works best for my situation..Thanks Again.
Pickle fork jet
When I taught my kids I looked behind the boat and found the smooth water about 50 ft back.
The stretch factor on nylon rope can make them bounce back & forth (rubber band effect)
I think #1 is the boat driver being lined up then a good even hard pull
#2 the size ski's to weight of skier!
I take off from the dock & a long rope stretches then snaps back when your weight hits the end. Turning 180 to head back is tough with a 75' rope (you'll be doing MPH coming around the curve)
Skiing is easer to learn than teaching kids to knee board ..
I learned to ski behind a 67 ford f-100!! We have irrigation ditch's here with roads along the top bank we stuck a 3" pipe in the bumper and didn't stop for 6 miles!!!!!! LET YOUR CONSCIOUS BE YOUR GUIDE!!!!
