Re: How long to flush salt from motor?
Good advise captpn.....Scout Sport Fish, I hope your not running it on the backflusher, I hope your using the muffs. If you run on the backflusher, there isn't enough water on your water pump impeller and you damage it, have seen it happen first hand.
Backflushing will flush the prop out enough also.
I wouldn't worry about the 2 or 3 hour drive home, the saltwater won't start to corrode things for a couple of days. I have seen plenty of engines that sit in the water and never get flushed and run forever. Doesn't mean I would do it, but if you flush your way ahead of the game.
My engine doesn't have the backflusher and my sits in the water, I put the ear muffs on it and lower it back down into the water and run fresh water through it that way. It's more of a brackish since it still pulls some saltwater in, but better than doing nothing. I've also seen some muffs that flush from both sides of the motor, might pick one of those up and see if it works better for me, maybe more fresh water will get in.
