Since I am mounting the unit in a kayak, I want to keep battery weight as low as possible.
I have a couple of NIcad rechargeable model airplane batteries that I would like to use. They put out 9.6 volts. I've run a FF once on 11.2 volts...I see that the unit will measure from 7 to 15 volts.
Seems to me if it will measure such a low voltage, then it is, in fact, running on 7 volts. I am mostly using it as a depth finder in 1 to 10 feet of water. Max accuracy is NOT necessary.
??? thanks Rich
p.s. Better yet, can I run it on 14.4 volts? I have a couple of old drill batteries that put out that much. Much easier to charge for me, too.
??? thanks Rich
