how many alternator poles 1981 johnson 50hp
ditchen
Is it 12 poles?
Tach setting is the reason I am asking.
Thanks in advance.
ditchen
Re: how many alternator poles 1981 johnson 50hp
I have seen a few charts that list the less then 70hp being 10 poles like this one:
http://www.jamestowndistributors.com/userportal/woeimages/howtos/Large/837i.jpg
and this one:
http://faria-instruments.com/site_manuals/IS0012u.pdf
Then I have seen it listed for 12poles as per the chart you referenced.
The reason for asking is I installed a tach and using the 12p (does not support 10 pole) setting and the rpm seems low 4500rpm. I am way under propped and know it is easily turning over 5k. Awaiting my tiny tach to verify.
HighTrim
Let us know what you find.
ditchen
wanted to update this. It is 10poles and not 12poles
Al-53
yes it is 10 poles..i ran into the same problem....when I bought a replacement tach i was told set to 6 poles....when i took the boat out the RPM's were low....I borrowed A friends Strobe tach....and found I was off by 1200 RPMs ...set it to 5 poles and was right on...
Al
