reefrunner7
- Joined
- Sep 20, 2009
- 124
Just wondering how many anchors you all carry?
Great thread. I was just wondering about what to carry.
If I wanted to stay on the water overnight, would two danforths secure my 22ft cuddy? I would use a somewhat sheltered inlet in about 6-10 feet of water. Or should I anchor deeper?
We generally overnight in similar water (semi-sheltered) about 15' deep. You don't need to anchor deeper unless tide swings pose a problem (grounding). Make sure you have some chain, and use adequate scope on the line (a factor of 5-7). If you have plenty of 'swing' room, I would not put out a stern anchor- if the wind shifts you want the boat to shift with it.
BTW, many believe that scope is based simply on the depth of the water you're in. That is not correct. The way to determine the basis for scope is to add the depth of the water to the height of your anchor attachment ABOVE the waterline. For example, if the water is 10' deep and your bow sits 3' above the water, your 'scope factor' is 13', not 10'. A scope of 5X means you'll pay out 65' of anchor rode.
My .02
