How Many Blades - Johnson 6R72D
dheitman62
I recently purchased a great little used motor - 1972 6hp Johnson 2-Stroke. When I got it, it had a very worn out Two-Blade Prop on it (8 x 7 1/4). I have since seen both two and three blade props on these motors. I want to replace this very worn out prop, but I'm not sure which to get 2 or 3 blades.
In the exploded drawings it's kinda hard to see conclusively which prop they are using.
The part # is 385319 but I have seen in this forum #387334 (8 x 7) which I know is a three blade prop.
Which one came on the original motor...?...Please Help...!
Thanks In Advance
jtexas
Re: How Many Blades - Johnson 6R72D
I can tell you firsthand that the '72 evinrude 6 came with a 2-blade prop.
F_R
387334 was an available option. It came as standard on a '76. Either one will work. Frankly, you wouldn't be able to tell the difference unless you have a tachometer and GPS. The '72 was semi-weedless, if that matters where you boat.
dheitman62
Yep, weedless does matter where I go. I think I'll stick with the 2-Blade.
Thanks Guys !!!
