how many bolts hold the transom on???
bob johnson
well we all know when we get these 30 year old and older boats, the transom is usually full of all the previous owners additional holes to mount what ever...
I sealed up a bunch and I am attaching a 15" x 12" 5/16" thick aluminum plate to the back where the motor mounts...seems there are 2 sets of odd motor mount holes and a bunch of other holes. I am just going to cover them all up.
in addition there are a dozen other holes i cant seem to see a need for....
so its a 1982 starcraft 18 SS.
I know we got the:
3 holes up each of the outer sides
the four motor mount holes based on the BIA standard pattern
the two sets of maybe 8-10 holes each for the inner transom brace that go down the center of the transom
the a row of maybe 10 or so holes in a line that holes the transom board "tray" to the aluminum sheet..
the a pair of holes on each side about 3/4 way up the transom for the SS U bolts for holding the boat down to the trailer.
the two large drain holes from the top pf the splash well.
thats all i can think of that should be there..
but i see many guys who have re done their starcrafts and from pictures of the inside looking at the transom, I am seeing a bunch of different bolts...( not screws!!) with huge washers ....that dont seem to go with anything that i mentioned already
so my question is. am i supposed to have some BOLTS helping squeeze the outer aluminum to the wood at various spots?
or ar the ones i catorgorized...good enough?
I know there will be a lot of support with all those mss screws that hold the splashwell to the wood..
bob
ezmobee
Re: how many bolts hold the transom on???
or ar the ones i categorized...good enough?
Yes. That's pretty much what I've got. I went the same route as you and did not just throw back in all the fasteners that were there just cuz they were there.
GA_Boater
My Nassau has 40 bolts. 18 just for the three knee braces and 8 for the 2 lifting handles along with 6 for the transom pad. 6 for the ends of the transom and 2 motor bolts (clamp-on) It's a lot of bolts!
1973Chieftain
My Jet had 25 structural bolts, not counting the 8 for the handles that I replaced with Ubolts. 4 vertically on each side, 12 for knee braces, and 5 for the motor board. The engine was 4 more, and the splashwell was held in with about 20-25 screws from the inside.
