how many carb kits?
ab1
I need to rebuild my carbs but I'm not sure how many kits I need, this will be my first rebuild. Does one kit just do one carb, or the whole engine. I suspect I need 6 but would like to verify before I order them.
93 150 Fast Strike - J150GLETR
ab1
Re: how many carb kits?
Just out of curiousity...there are actually only two carbs but 6 carb bodies, corrrect? I recall reading this somewhere but I've never done carbs. The service manual seems pretty straight forward about dissasembly and only mentions discarding the o-ring seal between the carb main body and throttle body, as well as the side cover plate gasket.
Will I need a new carb base seal? Anything else I should do while I'm in there?
It also mentions a screw (p/n 314610) to hold the throttle body and gasket in place. What size screw is this and is there an alternative?
