how many carbs do I have...Help
albass
I have a 1991 Fastrike model#J150GLEIS serial #G02956027 I thought I had 6 carbs and was told I only have 3 each feeding 2 cylinders is this correct my buddy has a 1995 fastrike and he has 6 carbs what correct???
dajohnson53
Re: how many carbs do I have...Help
Take off the large plastic intake cover and take a look! (but there's probably someone who actually knows!)
clanton
Looks like 6 carbs, 2 throttle valve bodies.
Dhadley
All 60* V6 motors have the same basic carb set up. As mentioned you have 2 throttle bodies and 6 carb bodies. Technically you have 2 triple throat carb assemblies. If you're going to clean the carbs you need 6 carb kits. One kit for each carb body.
ksubigbuck
Holy Schniekes that would suck.
Dhadley
If you want to get really confused - a 90* V6 looper has 4 carb assemblies.
