how many LBs of thrust?
flyguymv1
Dad and I have a Grady white....17" open bow with a 70 johnson sea horse....dont know how heavy the boat is....how many lbs of thrust do we need for trolling at normal troling speeds? also where do we mount it front of boat or back....where would be the best spot for it?and any info would be good thanks in advance!!!
roscoe
Re: how many LBs of thrust?
If you have a single battery for the trolling motor, get as many lbs thrust as you can. Something in the 50# range.<br /><br />If you are going with 2 batteries, a 24 volt motor in the 55-75# range.<br /><br />Front mount gives you more control.<br /><br />What is normal trolling speed? <br />For walleye in inland waters, about 1-2 mph.<br />For trout or salmon on the Great Lakes, about 3-6 mph.<br />If you are going to be strong fighting river currents or tides, get more power.
Luna Sea
I just put the 36volt MK on my 20' Lund. Course I had the room for 3 batteries. For that boat I'd suggest the 74lb thrust bow mount hand controlled. Do some searches on trolling motors. I bookmarked about 50 sites when researching mine. Also, get the 60" shaft for your Grady. I thought the 50 would work on my Lund, till I hit some chop..... Very nice people at Boaters World took it back and gave me the longer one. I consider myself lucky there....... :rolleyes:
Luna Sea
"Trolling at normal speeds"<br /><br />You may want a 10 or 15 hp outboard on back instead...............
