Re: How many poles?
Just to refresh my memory, I just now went thru the OMC factory service manual and read thru its entirety. There is no mention of the word "pole" pertaining to the charging system or any other component (Cover to cover). I started out in this line of work when all there was, pertaining to the Evinrude and Johnson outboards, was a magneto and a manual shift system..... and as the years went by, it was a simply matter for me to learn the new technology as it came into existence.
There are two tachometer setups if I remember correctly..... one operating off of the ignition system (Tiny Tach comes to mind), and one operating off of the charging system (Any tach that functions with the 6 pulse charging system). These tachs have a dial on the back of them which when set to #6 registers the true engine rpm. Setting it to any other number cause the tachometer to register a false reading as does the "pole" tachometer in the above posts.
All of the Evinrude and Johnson engines (with a few smaller hp exceptions) operate the tachometers with the six (6) pulse setup.
Since nobody here (including me) can come up with the proper pole setting, perhaps a phone call or email to the company manufacturing that pole tachometer could solve the problem.
Personally, if it were me, I'd sell that pole tachometer on eBay or elsewhere and purchase the proper six (6) pulse tachometer and be done with it.
