How many turns out do you set the low idle jet from lightly seated
909
... on a 1993-2002 9.9hp Johnson Evinrude.
Had to set it around 3.5 turns to get it to idle in a bucket without sneezing or dying.
Seems high, the older generation was only 1.5 turns
909
Did a thorough ultrasonic clean in the machine.
It's the plastic carb 255cc not the all metal 215cc
jimmbo
And you blew out all the passages with compressed air, and returned the carb to the Solvent for more soaking a few times?
909
I did 3 x 10 minute intervals with 16 to 1 rapid cleaner @ 30 degrees .
Blew out the passages
Used a thin wire.
jimmbo
Can you provide a Model #, so I can look up the correct carb?
jimmbo
You are adjusting Screw# 15? Did you have/use Rebuild Kit? If no, what parts did you replace?
909
Yes screw #15 . I didn't use a kit .
I used a thin guage wire.
909
I've gone through 3 carbs and they all seem to need at least 3 turns.
Some need 4 turns
flyingscott
That may not be wrong. It seems like the plastic carbs do require more turns out to run.
  • Like
Reactions: 909
909
Thanks. Between 3 to 3.5 to 4 turns seems to work.
kbait
Use a magnifying glass to look for a crack in the plastic carb top #10. That will cause a lean idle issue.
909
Luckily no cracks. I've also heard the top can warp.
Everything is working, as it should.
I suspect 3.5 turns is normal on plastic. 1.5 is normal on metal.
It would have to do with the pitch of the threads on the needle.----And the shape length of the needle and passage ways in the carburetor.----
909
After a bit of research, I found that Leroy's mentions :
The "Go To" thread back out to begin your idle setting will be about 4 1/2 threads out from bottomed out. I have found that on my motor about 4 5/8 turns out seems to be about right. The reason for this number of threads turned out instead of the 1 1/2 for the pre 93 motors is that these later plastic topped carburetors have a finer threaded idle needle. Like 0.45 MM per thread (or near 50 TPI) where the pre metal topped carburetors have 28 TPI.
This would mean I'm running lean @ 3.5 to 4 turns, or that their version of seating the screw is more agressive and requires more turns. My version of lightly seated is just that .... lightly seated.
