Re: how many volts to turn over a 93 90hp evinrude v4?
12 volts, but the full power of the battery is needed at the starter, so if the cables and connections are not in excellent condition, the starter won't work.
You can usually find the problem by touch, because the area of resistance will get hot.
You should also have the battery load tested at your battery store.
If you have a good DC voltmeter, you can perform a voltage drop test to find the weakness.
BTW, if all your battery can show is 12.2 after charging, you need a new battery.
