Thanks for all the detail
OK, well this falls into the category of "If you can think of it, then it probably already has been done"
Yeah, fraid so BUT, you could always make one Better? Brighter? Faster? Auto Dimming? What about like a star burst like design where there are concentric circle that expand out, each circle represents like 500 RPM, so there's 12 circles, the last circle is 6K RPM. Skies the limit....
I looked at the stator and it looks like 8 coils so I would assume that means 8 pules/rev?
No,
8 pole stator = 4 Pulse/Rev
12 pole stator = 6 Pulse/Rev
The tach has a switch for 1, 4, 3. So that would reference a standard 4 stroke tach of 2 cyl, 8 cyl, 6 cyl.. It says set it to 4.
Yes, for 4 stroke..........
2 cyl = 1 Pulse/Rev
6 cyl = 3 Pulse/Rev
8 cyl = 4 Pulse/Rev
In a typical v8 engine you get 4 ignition pulses per rev.so maybe you only get 4 pulses/rev on the outboard due to the full wave bridge diodes only outputting half the pulses coming in.
Typically, tapping the tach's sig off the output of the full-wave bridge (actually a frequency doubler) isn't done (that's DC due to that's connected to the battery and it is acting a filter), they simply just pick off the tach feed sig via the charge stator (AC, yellow wire side), you'll by default get 4 pulses/rev on your 2 stroke 90HP OB, that is, if your stator is truly 8 poles.......You certainly could be right, I'm not sure
Usually however a Merc in that/your 90HP size, they're typically 12 poles. As stated above, 12 poles = 6 pulses/rev, better double check yours again and/or perhaps a OB mech will chime in here and set the # of poles record straight here on that/your OB's stator.
BUT, If it turns out you really do have a 8 pole stator, set your 4 stroke tach to 4 pulses/rev (V8 4 stroke), tap the AC (either yellow wire) charge winding's on your OB and you're golden.............Winner winner chicken dinner eh?
So at 1000rpm = 4000 pulse/m or 66hz. Does that sound right?
Ummmm, 4 p/r * 1000 r/m (r's cancel) = 4000 p/m = 66.6 p/s = 66.6 c/s = 66.6 hz........yes
