Re: How much for getting leaks welded?
Yes...good point.
My boat does not have any rips or punctures in the metal. It does not have any corrosion either. I am guessing that it is the seams or loose rivets that are leaking. I know you can reset the rivets, and how difficult are the seams to weld?
I have heard that there may be some sort of material between the layers of aluminum that may prevent welding. Is this true?
I realize that I am going to have to remove the flooring once the spring comes and also take out all the soaking wet flotation foam, and then seal up the hull, one way or another. I don't have any pics, as the boat is covered under two feet of snow, and I don't want to touch it in case i break something. Winter makes everything so fragile...LOL!
Patrick
