Re: How much gas do you see when you run your old merc with the muffs?
Two stroke engines, have no built in lubrication, so we add "oil" to the fuel. Not all the oil is burnt up during combusion, the excess oil if exhausted out of the cumbustion chamber and mixed into the water through the exhaust hub. One reason why 4_stroke engines are much better for the enviroment. At low idles, larger engines don't burn all the fuel either, and as the other posted mentioned, you might be a tad bit rich in on the idle mixture (rich is better than lean). This is why you see the "oil" sheen" in the runnoff on muffs. IN the water it will appear "blue". Fuel in the water will appear like a "rainbow". If you have a bottom end leak, a quick change of gear lube will answer that. If the oil is "whiteish" then you got a leak.
