How much hp can I put on this boat?
Kristian
My family's got an old boat from around 1970 I can use if I want. And I want.<br />But which size engine will I get away with using?<br />It's a very small boat - 11' - and the specs from the manufacturer says it's 335 cm. long, 145 cm. wide and 63 cm. "deep". It weighs 98 kg. The factory specs also say up to 18 hp. You can see the boat for yourself here: http://www.skibsplast.no/arkiv.htm. It's boat no. 2 in the left hand column (called "Junior 11' m/dekk"). The hull is the same as the one called "Junior 11'".<br /><br />An engineer at the factory has told me that he thinks the boat can handle 30 hp, but he won't recommend it. Some years ago we used it with a 20 hp Mercury from the early 80's without any problems.<br /><br />How much hp can I put on this boat without killing myself - and still be able to get it out of the water? My guess is 30 hp and no more than 60 kg. What do you think?<br /><br />Any help and opinions very welcome.<br /><br />Sincerely Kristian<br /><br /><br />Thanks everybody. You've convinced me that I might be a bit eager killing myself. So I'll just go with a small engine. The transom still seems very firm and doesn't show any sign of damage from the 20 hp. overpowering. Any other way to check this than pulling it hard with my hands.
ajp
Re: How much hp can I put on this boat?
If the factory says 18Hp. Amatuer boat owners should follow that advice. <br /><br />Arlan
JB
Ahoy, Kristian.<br />Your specs say 18 HP. That is the maximum. More than that may destroy your boat, if it doesn't kill you first.<br /><br />Before you use the boat, carefully inspect the transom to be sure it wasn't damaged by the slight overpower with the 20hp.<br /><br />Sorry to sound like a killjoy, but those numbers (max HP rating) are not arbitrary. In many places exceeding that rating will get you a fine.<br /><br />Happy boating.<br /><br />Red sky at night. . .<br />JB :)
Makofanatic
its only a 11'and probably isnt worth anything,put a 25hp on it and drive it till the transome falls off sounds like thats what you want to do anyway so just do it. :cool:
Ranger354
Kritian,<br /><br />Insurance and liablity would go by the manufctures specs. Evinrude used to make an 18 hp years ago and would most likely match up pretty well with this boat. Trying to find an 18 would be hard. The new 15 hp evinrudes (or merc, yamaha, etc) probably has close to the same prop output as the old 18. <br /><br />Play it safe and go with a 15hp.<br /><br />Or paint "Jetty Smasher" on the bow in red paint and put a 35hp on it.
