hi how much oil does 1985 TRS outdrive hold Thanks
O oldfordcrap Petty Officer 2nd Class Joined Jan 11, 2011 Messages 120 Apr 13, 2011 #1 hi how much oil does 1985 TRS outdrive hold Thanks
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,480 Apr 13, 2011 #2 Re: how much oil does 85 trs drive hold Schematic shows 2 vent screws, so I`d say fill from the bottom hole untill it comes out the top hole.guessing under 3 Qts.
picklenjim Chief Petty Officer Joined Mar 11, 2009 Messages 528 Apr 13, 2011 #3 Re: how much oil does 85 trs drive hold 3 Quarts in the drive and 1 more in the reservoir. You will need 4 quarts if you reservoir is now empty. Draining the drive will also drain the reservoir. I usually let mine drain overnite to be sure all drains out.
O oldfordcrap Petty Officer 2nd Class Joined Jan 11, 2011 Messages 120 Apr 14, 2011 #4 Re: how much oil does 85 trs drive hold thanksfor the info
